News: Welcome to AudiRevolution.net
   Home   Help Login Register
Pages: [1]   Go Down
  Print
Author Topic: 0B5 DSG, S-tronic, 7-speed 35000 mile service, fluid and filter B8 A4, A4, A5,  (Read 43376 times)
NICETTS
Newbie
Member Rating: 5
Offline Offline
« on: January 20, 2015, 12:46:04 PM »
I need to do the service on our new S5.  Some decisions I made.  One I went with Luquimoly DSG Oil as it was designed with VW and Audi and met the required spesifications.  Reason $37 list price $26 my cost for Audi bottled fluid and $16 a litre for Liquimoly.  I also did the spark plugs as they to were do.
Total cost for the DSG service is $150.  That includes 8 litres of fluid, a filter a ridiculously priced o-ring and a crush washer for the drain plug.
I also used the ECS DSG tool I already owned for the 6-speed DSG in my TTS.
1.  Lift the car level and not on the wheels.
2.  Remove the cover panels.
3.  Remove the drain plug from the transmission pan.
4.  Reinstall the drain plug after its done draining with a new crush washer and torque to 45nm.
5.  Remove the filter cover using a 17mm wrench.
6.  Reach up and pop the filter out.
7.  Lubricate the new filters small o-ring with some oil.
8.  Lubricate with some oil the new filter cover o-ring and install.
9.  Re-install the filter cover and torque to 8nm.  You can get an extension with a universal to the cover from the front.
10. Remove the oil fill plug in the middle and halfway up the left side of the transmission.
11. Install the fill hose into the hole.  I tie wrapped it to some piping to keep it in the hole.
12. If you are using the factory or some other fill tool connect the air hose up with 10-20 psi and screw the first bottle in then turn it upside down and open the valve to pressurize the bottle.
13. Put 4 litres in the transmission.
14. Then follow the attached procedures that in summary have you start the car run the transmission through the gears.
15.  Then add fluid till it slowly runs out the fill hole.
16.  Warm it up to 30c to 50c and fill it till it dribbles out the hole.
17.  Put the fill plug back and torque it to 45nm.
18.  Button it back up.
Logged
bangoman
Sr. Member
Member Rating: 49
Offline Offline
Re:
« Reply #1 on: January 20, 2015, 08:24:31 PM »
Nice DIY. Really helps to see the real photos with the schematics.
Logged
...those guys would have bought a box full of sheep shit if it was packaged in a shop with a lift and a shiny floor and came with a nice dyno chart. If you tried to tell them their box of sheep shit stunk, they'd cry that you were a sheep-shit hater....
NICETTS
Newbie
Member Rating: 5
Offline Offline
« Reply #2 on: January 21, 2015, 05:56:06 AM »
Thanks, I couldn't find the info anywhere on the web in a diy.
Logged
sakimano
King of the Inconvenient Truths
Hero Member +
Hero Member
Member Rating: 286
Offline Offline
WWW
Re:
« Reply #3 on: January 21, 2015, 05:59:42 AM »
Excellent work.   Plus karma
How many miles are on the car that made you do this?
Logged
sakimano = 12.51 @ 110.53 = fastest privately owned and operated Avus Silver RS4 in Canada with a driver over 6'5" tall and a golf handicap of 2 or less
"Everyone is 'fastest' if they create their own category." - Jake@JHM
NICETTS
Newbie
Member Rating: 5
Offline Offline
Re:
« Reply #4 on: January 21, 2015, 07:23:25 AM »
Was at 44,000 miles! Wasn't done at 35,000, we just got the car.
Logged
FastEddie
Full Member
Member Rating: 25
Offline Offline
« Reply #5 on: January 22, 2015, 11:28:22 AM »
This didnt pop up for me on not seen stuff. Great write up as always
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.14 | SMF © 2006-2011, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
